OpenSpan Inc
OpenSpan Inc
OpenSpan Inc
Posted: Jul 9, 2021
Last activity: Jul 9, 2021
Last activity: 9 Jul 2021 13:17 EDT
Getting 64-bit datasources to appear
I was trying to use the ODBCQuery connector to connect to Oracle database. If the datasource is 32-bit, I see it as an option on the Connections tab. But if it’s 64-bit, it doesn’t appear on the Connections tab (in the datasource of ODBCQuery connnector).
How can I get 64-bit datasources to appear so I can select them?
@Ralph_Jordan
Datasource configurations are have a specific bitness. Pega Robot Studio runs in 32-bit mode, so only 32-bit datasources appear on the Connections tab. You have to set up both the 32-bit and 64-bit datasource in ODBC. After you do that, then you will be able to see 64-bit datasources. Keep in mind that when running the solution, you can use a 64-bit version of Robot Runtime.
