TECHMAHINDRA
Last activity: 14 Jul 2020 9:02 EDT
Generating word document within case lifecycle
Requirement is to generate the word document within case life cycle for which i called the utility smart step - Generate Word Document" in case designer.
However, i would like to call pega section in the generated word document. I have used the document template tags described in https://community.pega.com/sites/default/files/help_v84/procomhelpmain.htm#case-management/case-documents-tags-ref.htm
<pegaref config={"name":"GenerateDocSectionCheck","type":"S"}>
Generated Document is containing the Div tags instead of the section content.
please find the attached template passed to the utility.
please let me know if you have faced the same issues and how to solve this issue.
