Generating Rule schema objects migrate.sh failing from 5.5 to 7.1.9
HI,
We are upgrading from pega5.5 to pega 7.1.9 , our migration and rule upgrade got completed successfully. Now when we are running migrate scripts to generate rule schema objects we are getting below error. We have given target schema as new pega7 rules schema in migratesystem.property file (as per Pega Upgrade guide). But one of the pdn link suugests to give target as old schema and source schema name as your new rule schema. Please advise.
https://community.pega.com/support/support-articles/error-while-generating-rules-schema-objects
BUILD FAILED
/opt/wassource/WAS_DUMP/PEGA-EAR/scripts/migrateSystem.xml:501: java.sql.SQLSyntaxErrorException: ORA-00903: invalid table name
HI,
BUILD FAILED
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:445)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:879)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:450)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:192)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:193)
at oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:873)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1167)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1289)
at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1491)
at oracle.jdbc.driver.OracleStatementWrapper.executeQuery(OracleStatementWrapper.java:406)
at com.pega.pegarules.util.anttasks.CheckForUncommittedHotfixes.execute(CheckForUncommittedHotfixes.java:43)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:68)
at net.sf.antcontrib.logic.IfTask.execute(IfTask.java:197)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:154)
at org.apache.tools.ant.Target.execute(Target.java:435)
at org.apache.tools.ant.Target.performTasks(Target.java:456)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1393)
at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1248)
at org.apache.tools.ant.Main.runBuild(Main.java:851)
at org.apache.tools.ant.Main.startAnt(Main.java:235)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
