Caught exception "PegaBulkMover:: SQLException loading database" while running migrate.sh
while running the migrat.sh scripts to migrate rule tables to the new schema, we got the below error while inserting data in the last table. All other tables have been migrated successfully in the new schema and have all the data.
Thu Apr 21 04:27:33 EDT 2016 (INFO): Column Index: 44 Name: PZINSKEY 12 VARCHAR2 Not Nullable 255
Thu Apr 21 04:27:33 EDT 2016 (INFO): Column Index: 45 Name: PZPVSTREAM 2004 BLOB Nullable 4000
Thu Apr 21 04:27:33 EDT 2016 (INFO): PegamoveData: SQL Statement Generated: Insert into PEGA_RULES.PR4_RULE_FILE (PXCREATEDATETIME, PXCREATEOPNAME, PXCREATEOPERATOR, PXCREATESYSTEMID, PXHOSTID, PXINSID, PXINSNAME, PXINSTANCELOCKEDBY, PXINSTANCELOCKEDDATETIME, PXINSTANCELOCKEDKEY, PXOBJCLASS, PXUPDATEDATETIME, PXUPDATEOPNAME, PXUPDATEOPERATOR, PXUPDATESYSTEMID, PYAPPLICATIONNAME, PYBASERULE, PYBUNDLETYPE, PYBUNDLENAME, PYCIRCUMSTANCEDATEPROP, PYCIRCUMSTANCEDATE, PYCIRCUMSTANCEPROP, PYCIRCUMSTANCETYPE, PYCIRCUMSTANCEVAL, PYCLASSNAME, PYFILENAME, PYFILETYPE, PYFILECHECKSUM, PYINTERFACE, PYLABEL, PYMETHODSTATUS, PYRELATIVEPATH, PYRULEAVAILABLE, PYRULEENDS, PYRULENAME, PYRULESET, PYRULESETVERSION, PZRULESETVERSIONMAJOR, PZRULESETVERSIONMINOR, PZRULESETVERSIONPATCH, PYRULESTARTS, PYSORTDATECIRCUMWITHINRSMAJOR, PZIMPLEMENTATIONKEY, PZINSKEY, PZPVSTREAM) Values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
Thu Apr 21 04:27:36 EDT 2016 (INFO): PegaBulkMover: Loaded 1000 out of 12132 Rows
Thu Apr 21 04:27:39 EDT 2016 (INFO): PegaBulkMover: Loaded 2000 out of 12132 Rows
Thu Apr 21 04:27:43 EDT 2016 (INFO): PegaBulkMover: Loaded 3000 out of 12132 Rows
Thu Apr 21 04:27:47 EDT 2016 (INFO): PegaBulkMover: Loaded 4000 out of 12132 Rows
Thu Apr 21 04:27:52 EDT 2016 (INFO): PegaBulkMover: Loaded 5000 out of 12132 Rows
Thu Apr 21 04:27:57 EDT 2016 (INFO): PegaBulkMover: Loaded 6000 out of 12132 Rows
Thu Apr 21 04:28:01 EDT 2016 (INFO): PegaBulkMover: Loaded 7000 out of 12132 Rows
Thu Apr 21 04:28:07 EDT 2016 (INFO): PegaBulkMover: Loaded 8000 out of 12132 Rows
Thu Apr 21 04:28:12 EDT 2016 (INFO): PegaBulkMover: Loaded 9000 out of 12132 Rows
Thu Apr 21 04:28:19 EDT 2016 (INFO): PegaBulkMover: Loaded 10000 out of 12132 Rows
Thu Apr 21 04:28:21 EDT 2016 (INFO): Encountered exception during processing!
null
at java.nio.Buffer.nextPutIndex(Buffer.java:513)
at java.nio.DirectByteBuffer.put(DirectByteBuffer.java:291)
at com.pega.pegarules.util.deploy.PegaBulkMover.loadDatabaseTable(PegaBulkMover.java:921)
at com.pega.pegarules.util.deploy.PegaBulkMover.process(PegaBulkMover.java:567)
at com.pega.pegarules.util.deploy.PegaBulkMover.main(PegaBulkMover.java:222)
PegaBulkMover:: SQLException loading Database.
at com.pega.pegarules.util.deploy.PegaBulkMover.loadDatabaseTable(PegaBulkMover.java:1080)
We are upgrading from 6.2 sp1 to 7.1.9 in tomcat and oracle 11g
