Infosys
Last activity: 25 Jan 2023 4:35 EST
FUA Instance-NullMyStepPage
Getting a Fail error on tracer on a property set method ( The reference code block is not valid. Reason : FUA Instance-NullMyStepPage)
Any solution or help will be great.
Accenture
SG
Can you explain further more on you code config ?
Did you use parameter type page in your code?
Infosys
@VinayKumarL16594575 setting property values to local properties and parameter page is "unnamed".
Accenture
SG
@BinithR13 Can you share the screenshots ?
Infosys
@VinayKumarL16594575 shared the SS and also the local variables are not taking the property value. There is no step page provided in the property set method.
@BinithR13 Can you also add the screenshot of your Primary Page in tracer
Infosys
@SrinidhiMI see it now, step page is blank in tracer. The page is pyLanding which is not showing.
Accenture
SG
Define the step page(pyLanding) in pages and class tab and refer the same page on the step where you are doing property-set.
Infosys
@VinayKumarL16594575 did the same but it didn't work, still showing no step page.
@BinithR13 Please define the page where you would like to set the properties in pages and classes tab and use it as a primary page for property set
@BinithR13 Are you trying to save the page in which you are setting the values
