T-Systems ICT India Pvt Ltd Pune
Posted: Jul 22, 2025
Last activity: Jul 24, 2025
Last activity: 24 Jul 2025 14:01 EDT
Formatting of Generated PDF Differs Between DEV and QA Environments
We are experiencing an inconsistency in the PDF formatting generated via the pxCreatePDF smart shape/activity across our environments.
In Development, the PDF is rendered with the correct layout, fonts, and styles as expected.
In QA, the same rule and parameters produce a PDF with different formatting
I have attached the generated PDF from both the Environment for your reference.
HI @Sagar Chavan !
I noticed you hadn't received a reply on your Question and wanted to direct you to one of our new Expert Circles that I think will be helpful in recieving a reply! I'd like to suggest reasking your question in our User Experience Expert Circle listed below. Our Expert Circles are pretty active and I think it's the best for you to get a quick reply!
Let me know once you've posted and I'll see what I can do to help you receive a reply!
