Flow Resume - After Assignment deletion
I want to resume the flow after an assignment deletion. I'm not sure on the Flow Action name at that movement. Can any one help ?
Scenario : I want to remove the assignment from specific workbasket as it does not need to submitted for further processing and resume the flow without any impact.
Hi Rajsri,
What do you mean by deleting the assignment? Are you deleting assignment instance from DB? Or are you deleting the assignment from the flow?
If there is any other flow that has assignments, then you can set a ticket so that this ticket will trigger the resuming of the problem flow.
Please share your thoughts.
-Ravi.
