UBS
UBS
CH
UBS
Posted: Nov 30, 2023
Last activity: Dec 13, 2023
Last activity: 13 Dec 2023 2:48 EST
file listener not starting after a system restart
Hi all
I've the following problem:
- file listener not starting after a system restart on the right node
- Manual restart works good
I've tried to follow the indication here:
QUESTION:
since I don't see any error in the log, is there a way to increase log level setting?
@PieroGuido
Can you try by changing the node type ?
Maybe recheck & re-apply nodeType to avoid invisible char.
Please also hardcode any value in file listener if relevant for testing purpose.
Please confirm that the system AG is the same as your AG when you connect.
Since there's nothing printed in logs, it really looks like that the main condition for the nodetype is not fulfilled.
What you could also try is to put incorrect setup on purpose to trigger a failure.
- non existing directory to read, incorrect requestor login
Last, I think that DSS must be set to true
Pega-Engine • prconfig/initServices/initFile/default
Regards
Anthony
