Failed To Open Queue
I am using the below function to queue an activity
Object o = tools.getRequestor().queueBatchActivity("Work-", "ActivityName",tools.getParameterPage(),null,otherPages,false );
While trying to queue, I am Getting the below error sporadically:
Failed to send message Failed to send message, reason: Failed to open queue [] on NYT0 using open options [8208]; completion-code=2[FAILED], reason-code=2085[UNKNOWN_OBJECT_NAME]
Any Solution for this ?
***4/7/2017- edited by moderator, Maryrita; moved from Upgrade Center to Product Support***
What is the activity you're trying to call doing? Is it reaching out to some external system?
Are you able to run that activity by itself and cause the same issue or does it only happen if you queue it?
