Publicis Sapient
Last activity: 13 May 2022 2:21 EDT
Queue Processesor Error: Failed to prepare partitions
I created a dedicated queue processor(delayed) with different processing times for different scenarios
But the queue processor doesn't seem to be running in the Admin Studio,
when I try to click on the 'start' link
I'm facing the error: "Queue processor couldn't reach a stable state. Please check after some time.".
Logs shows this error: "DemoQueueProcessesor couldn't come to a stable state. Status: Initializing "
Data Flow warning : "Failed to prepare partitions"
Also I wasn't able to find my kafka cluster in the kafka-data in tomcat folder
@PoojaPalla I can see multiple previous posts related to this issue but none have accepted solution.
3 scenarios to be checked is:
(i) is QueueProcessor Activity is taking lot of time to execute ?
(ii) Is the stream node is reachable ?
(iii) Sufficient disk space for kafka-data
Please have a looks at below posts if it helps, otherwise better to raise a Pega SR for this issue
https://collaborate.pega.com/question/queue-processor-couldnt-reach-stable-state-please-check-after-some-time
https://collaborate.pega.com/question/failed-prepare-partitions-run-pybiincrementalindexer
https://collaborate.pega.com/question/stream-service-exception-during-startup
