aaseya it services pvt.ltd
SA
Last activity: 11 Sep 2019 9:39 EDT
Extract Rule is not Working
Extract Rule is not working Please refer the document for issue.
Please enable below loggers in ALL level and run the extract rule and share the BIX log file.
com.pega.pegarules.data.internal.access.ExtractImpl
com.pega.pegarules.data.internal.access.ExtractParameters
com.pega.pegarules.data.internal.access.DatabaseUtilsCommonImpl
Kranthi
SA
Can you please elaborate where to enable the loggers
SA
I didnot get any logfiles after enabling the loggers and second logger i didnot found
Remove your name in Filer by, then click apply and go to last page.
SA
I have Removed
Can you go to your 'D:\BIX Files' and see if 'ExtractDetails.xml' file is available after running the extract rule?
Thank You,
SA
I checked it already but not found file
Does the 'BIX Files' folder exist in your D drive?
Thank You,
SA
Yes
Hi Mounika,
Could you please check if the operator from which you are running the BIX extract has PegaRULES:SysAdm4 role in the Access Group (while running extract rule, it checks for access role to be either "PegaRULES:SysAdm4" or .pxThread.pxCurrentApplicationName + ":Administrator").
Have you tried this with any other operator?
Also were you able to enable the loggers that Kranthi has suggested?
SA
yeah the operator having the sysadm4 role and i am not able to find the second logger which kranthi has mentioned
Hi ,
We have tried to reproduce your scenario in Pega7.4 , it is working fine for us . Could you please let us know below details for further investigation.
Pega as well as BIX version?
Do you see ExtractDetails xml file in your Bix Files folder?
What is the status of test Connectivity ?
How you are running the extract rule?
What is the result for other output format?
Also can you create another extract rule and verify the scenario.
Thank You,
