Exposed property Not available in reports
Hi Team,
There is a Property been exposed to made it available for reporting. when I am trying to add it to a report of its same class, it is throwing below error as It is not valid. (but it is present in the same class and column exposed in back end table), This issue happening only in production but worked in UAT.
Q: Can I please get to know what are the scenarios causing this issue and resolution available? Please let me know if would provide more information when required.
Version 6.3 SP1
Property Name:
This is not a valid property, or this is a property that cannot be used here.
and below is the error traced while saving the report after adding the field.
Thank You,
Mathan
Hi Team,
Version 6.3 SP1
Property Name:
Thank You,
Mathan
***Updated by moderator:Marissa. Removed user added Ask the Expert and #helpme tags. Apologies for confusion, shouldn't have been an end-user option***
