Expose a Property as a column in a table by a sql query
Work Class has an Unexposed Property. A new column has been added to the corresponding DB table for the work class. Database table instance is saved in the designer studio. When creating the new cases, the values for the property are not added to the exposed column. Is there any additional change need to be done to see the values in the exposed column? The property optimization tool is not going to be used there are a lot of data and system gets hung when using the property optimization tool.
