Export to PDF functionality is not working fine
I had requirement to export the data to pdf file .I had used report definition to fetch data & am calling report definition & exporting data to pdf using pzViewExportToPDF OOTB activity. I am getting data in pdf but data is getting trimmed for some of columns in exported pdf if string length is more & alignment of columns, back ground styling is different & grid loses all formatting.I checked pdn & found the hot fix SA-38698 (https://community.pega.com/support/support-articles/export-pdf-issues-report-definition).
Will the hotfix resolve the above issue ? & could you please provide solution or any valuable input that could resolve the issue.
Anudeep
Hi Anudeep,
SA-38698 is for Pega 7.2.2, what is the Pega version your application makes use of?
Hfix provided under this SA seems to be addressing issue w.r.t column headers not visible
