Serendebyte Inc
Event logging using Windows Event Viewer
Hi, can someone give me guidance on how to enable my automation so that when it logs it is visible in the Windows Event Viewer? I've read through the documentation but can't quite seem to get it to work. A project example which incorporates event logging into the project would be great!
Are you using the event log component?
http://help.openspan.com/80/Components/Event_Log_Component_-_Properties,_Methods_and_Events.htm
http://help.openspan.com/80/Diagnostics/Event_Log_Configuration.htm
