Error:This Operation requires a lock on the object before it can Proceed
Hi Team,
We are facing some issue with DWA links which are used for capturing the RFI's sent by the user in our application.
Issue Description:
When clicking on DWA link and submitting the from for first time it will throw an error with "Some fields cannot be blank".After filling the required the fields and submitting the form for second time it is throwing an Error:This Operation requires a lock on the object before it can Proceed.
We have checked the code and found that the flow action which is being called after clicking on submit button is not being called again and directly it is pointing to end of the flow. Also the work object lock is being lost after submitting the form for second time.
Any suggestions how to overcome to this issue.
***Updated by moderator: Lochan to close post***
