GDIT
Last activity: 6 Aug 2019 15:40 EDT
Error running BIX PegaSample!Sample extractor
I'm running Pega 8.2 with BIX installed and am using the attached prbootstrap.properties, prconfig.xml, and bix.sh files (renamed to allow uploading; sanitized prior to upload). I am able to successfully connect to the PostgreSQL database using other Java apps and pgAdmin.
When I execute bix.sh I get the attached output (bix.log.txt). The classpath is:
./lib/jsr94-1.0.jar:./lib/prbootstrap-api.jar:./lib/prbootstrap.jar:./lib/prdbcp.jar:./extra-libs/postgresql-42.2.5.jar
The JDBC driver is present on the classpath, however, as you can see in bix.log.txt, there is still a problem connecting to the database ("Missing JDBC driver class setting"). Further down it appears prbootphase2.jar is expected to be loaded from ./lib/boot but that file isn't provided with the Pega Additional_Products.
Has anyone else encountered/overcome either of these?
GDIT
Figured it out. The dbcpsource didn't follow the "<unique-identifier>.<dbtype>" naming convention.
Could you please review your prbootstarp.properties file if the DB URL,username , password, rule schema name and data schema name are correct.
Also could you please provide the snapshot of the BIX configuration.
Thank You,
Try to include current directory in your classpath:
.:./lib/jsr94-1.0.jar:./lib/prbootstrap-api.jar:./lib/prbootstrap.jar:./lib/prdbcp.jar:./extra-libs/postgresql-42.2.5.jar
Regards
Simon
GDIT
Thanks for the responses. I verified the database URL, username, password, and schema. Found a typo on the schema (rulesset rather than ruleset). Otherwise, they are correct. Also added current directory to the classpath. I can successfully connect to the database and query rulesset.pr_operators in a stand-alone Java app. The following "BIX invocation" still apparently fails to connect to the database:
java -Xms512m -Xmx768m \
-Dpegarules.config=./config/prconfig.xml \
-Dcom.pega.pegarules.bootstrap.properties.url="file:///home/sdcavan/projects/BIX/config/prbootstrap.properties" \
-Dpegarules.logging.configuration=./config/prlog4j2.xml \
-Dcom.pega.pegarules.bootstrap.ignorejndi=true \
-cp ".:./lib/jsr94-1.0.jar:./lib/prbootstrap-api.jar:./lib/prbootstrap.jar:./lib/prdbcp.jar:./extra-libs/postgresql-42.2.5.jar" \
com.pega.pegarules.pub.PegaRULES com.pega.pegarules.data.internal.access.ExtractImpl \
-I PegaSample_Sample.xml
And I get the following results:
Aug 05, 2019 9:46:34 AM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
1050: Loading bootstrap properties from file:///home/sdcavan/projects/BIX/config/prbootstrap.properties
Aug 05, 2019 9:46:34 AM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
INFO: Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
INFO: Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
1050: Bootstrap datatables schema: rulesset
1050: Insufficient data supplied in prbootstrap.properties to create a datasource
1050: Missing JDBC driver class setting "null.jdbc.class"
1050: Unable to locate archive.properties properties, setting warVersion to -1
1050: Engine schema defined in allclasses: rulesset
1050: Engine classes schema: rulesset
1050: Assembled classes schema: rulesset
1050: prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
1050: PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: null
Aug 05, 2019 9:46:34 AM com.pega.pegarules.internal.bootstrap.PRMiniLoader
1050: Will load phase 2 bootstrap from Pega-EngineCode:
/home/sdcavan/projects/BIX/lib/boot/prbootphase2.jar (No such file or directory)
Perhaps executing with a non-standard classpath (e.g. JUnit tests)?
1050:
============ PegaRULES Bootstrap Configuration ============
Date: Mon Aug 05 09:46:34 EDT 2019
Java Version: Oracle Corporation 1.8.0_201
Configuration: file:/home/sdcavan/projects/BIX/config/prbootstrap.properties
Pega-EngineCode:
(!) Ignored JNDI Options
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
SEVERE: Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:731)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:673)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:419)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
Aug 05, 2019 9:46:34 AM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
SEVERE: Problem during method invocation (main)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.data.internal.access.ExtractImpl
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:219)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:335)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:315)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:420)
Exception in thread "main" java.lang.RuntimeException: Problem during method invocation (main)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:279)
Caused by: java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.data.internal.access.ExtractImpl
... 1 more
Could please review the below lines in prbootstrap.properties.
com.pega.pegarules.bootstrap.allclasses.schema=ruleset (should be rule schema name) com.pega.pegarules.bootstrap.datatables.schema=ruleset (should be data schema name)
Also check the below command which is working fine for me.
java -classpath ".;./lib/prbootstrap-7.4.0-185.jar;./lib/prbootstrap-api-7.4.0-185.jar;./lib/prdbcp-7.4.0-185.jar;./lib/jsr94-1.0.jar;./lib/postgresql-42.2.2.jar;" -Dpegarules.config="/config/prconfig.xml" -Dcom.pega.pegarules.bootstrap.properties.url="file:///C:/Users/xxx/enablement_software/115943_Pega7.4/Additional_Products/BIX/config/prbootstrap.properties" -Dpega.prbootstrap.config="config\prbootstrap.properties" -Dcom.pega.pegarules.bootstrap.ignorejndi=true -Dpegarules.keyring="C:\Users\xxx\enablement_software\115943_Pega7.4\Additional_Products\BIX\config\pegarules.keyring" -Dpegarules.logging.configuration="config\prlogging.xml" com.pega.pegarules.pub.PegaRULES com.pega.pegarules.data.internal.access.ExtractImpl -a usernameforprpclogin -p passwordforprpclogin -i bixextractclassname!bixextractrulename
Thank You,
GDIT
I have the following for prbootstrap.properties:
com.pega.pegarules.bootstrap.ignorejndi=TRUE
com.pega.pegarules.bootstrap.allclasses.dbcpsource=bixpg
bixpg.url=jdbc:postgresql://__DBHOST__:5432/pegadb
bixpg.username=__DBUSER__
bixpg.password=__DBPASS__
postgresql.jdbc.class=org.postgresql.Driver
com.pega.pegarules.bootstrap.allclasses.schema=rulesset
com.pega.pegarules.bootstrap.datatables.schema=rulesset
The schema really is "rulesset" rather than "ruleset".
The error/output (see below) makes me think the jdbc class property isn't correctly named:
Aug 06, 2019 7:39:48 AM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
GDIT
