Sun Life Financial
Last activity: 26 Nov 2019 20:28 EST
Error message is disappearing when focus shifted from required date field.
I have a date field(text input + calender display mode) and is a required field.
And theres' a edit validate rule on the property being used here.
When we enter some input data, edit validate runs and throws error on the screen. As its a text input input and calender mode of display, still cursor is on the same field.
So, here when we click outside the field, error message disappears. Its not persistent.
How the keep the error message constant even though required option enabled for the control.
Also, I have tested with "IsFutureDate" edit validate rule available and still error persists on the UI after focusing out from the control.
