Error Logging inside deployed Automation package
from Few days i was wondering and searching if we can see somewhere in pega Designer studio or somewhere else in robot Manager.. Below is the Problem statement
I have created a automation in Pega Robotics installed on my machine, i have used RobotActivity from the tool box and its components and methods, Now Robotactivity has three status inbuild in SetCompletionstatus Method below
1-Completed
2-CompletedwithErrors
3-DidNotcomplete
It also has two parameter which we can send along with the above first one is code and send one is message which are very useful if we come across an error inside the automation flow or want to send some custom message for extra detailed logging. I have created the whole flow and sending the values manually for code and message in my automation but when i run the case from the pega designer studio case flow i can only see the three status for 3 different cases in audit section but i am not able to see the code and message i am sending along with the status in audit section of designer studio or robot manager
Every configuration part is done correctly. Bot is running fine but just the wondering how can i see these in Audit. I have attached an image to show the parameter i am talking about.Please help
1-Completed
3-DidNotcomplete
Can Anyone Reply on this?Please help me
