RBC
Last activity: 17 Oct 2017 9:19 EDT
Error launching windows application from Pega Robotics
In QA testing of a RDA process that launches a windows application we are encountering an error indicating" Error opening process 9480: 0x5" Where can I find information on the error, a cause and most needed a FIX? The RDA is launch as a user logs in via the registry startup script, and then it is supposed to start the ALP application.. This fails (log4net is below) and the user is left hanging as to whether the RDA or alp application have started or are stable..
Any input is appreciated.. REgards, Rob
Info | 10:48:27.005 AM | 25 | STA | Windows Adapter | ALP | | WM_OS_PROCESS_CREATED received
Info | 10:48:27.009 AM | 25 | STA | Windows Adapter | ALP | | Attaching process 9480 (C:\RBFG\ru\ru07\RUAPPBAR.EXE) to WindowsProcess object
Info | 10:48:27.012 AM | 5 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Found internal SetState2
Info | 10:48:27.012 AM | 5 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Calling base...
Info | 10:48:27.013 AM | 5 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Base called
Error | 10:48:27.051 AM | 25 | STA | Windows Adapter | ALP | OpenSpan.Adapters.Windows.WindowsProcess-5655257 | Error opening process 9480: 0x5
Verbose | 10:48:27.070 AM | 25 | STA | Matching | ALP | ActiveXFactory-59107228 | IsMatch failed - target: RUAPPBAR.EXE (PID: 9480)
Verbose | 10:48:27.070 AM | 25 | STA | Matching | ALP | DotNet20Factory-22049402 | IsMatch failed - target: RUAPPBAR.EXE (PID: 9480)
Verbose | 10:48:27.070 AM | 25 | STA | Matching | ALP | WinInetFactory-31842847 | IsMatch failed - target: RUAPPBAR.EXE (PID: 9480)
Verbose | 10:48:27.070 AM | 25 | STA | Matching | ALP | MicrosoftHTMLFactory-4874511 | IsMatch failed - target: RUAPPBAR.EXE (PID: 9480)
Verbose | 10:48:27.070 AM | 25 | STA | Matching | ALP | DotNet40Factory-54991767 | IsMatch failed - target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | webPageALP-54194842 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | Unit_Directory-5713706 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | UD_Top_Frame-1512121 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | webPage1-51366806 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | WebPageDDA-12663471 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | DDA_Subtraction_Deposit_Services-32817500 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
Info | 10:48:27.072 AM | 25 | STA | Matching | ALP | DDA_SuccessfulAccountChangeForm-27295387 | IsMatch: Target type OpenSpan.Adapters.Windows.WindowsProcess is not allowed for this control. Target: RUAPPBAR.EXE (PID: 9480)
***Updated by Moderator: Marissa to add SR Details***
