Pegasystems
Last activity: 30 May 2019 10:39 EDT
Error importing PegaMarketing_Core_0802.zip
Getting the following exception during the import:
Import cannot proceed due to exception: java.lang.IllegalStateException: Improperly form view metadata element: <?xml version="1.0" encoding="UTF-8"?><database catalogName="" databaseName="ExternalMKTData" schemaName="" type="6"><view description="View V_MKT_CUSTOMER_SEGMENTS" name="V_MKT_CUSTOMER_SEGMENTS" ruleset="Pega-RULES"><select/></view></database>
Configured the Database rule per directions and successfully tested with JNDI config. This just points to the PegaDATA schema.
2. Configured schema reference (customerdata) in context.xml alongside PegaRULES and PegaDATA entries. Tried also setting this up as a DSS originally per instructions with same results.
3. Marketing tables were created manually b/c Pega did not seem able to identify the schema.
