Ernst & Young LLP
Error deserializing Design Component -
Hello - I'm encountering an error regarding missing Properties in Interaction Manager for State and Zipcode (screenshot attached). However Object Inspector -> Properties shows State and Zipcode when InteractionManager is selected in the Object Explorer. Also double-checked the Configuration File and both State and Zipcode are available under "Context".
Has anyone seen this error before?
Thanks!
Logistics Health Inc
Thank you all for your help... Adding the string variable, saving, and then cleaning/rebuilding resolved my issue.
Ernst & Young LLP
To add some more context - when building the attached prompt appears for State and Zip:
Could not find Property 'interactionManager1.State'
Could not find Property 'interactionManager1.Zip'
Is there anywhere outside the XML file where new context values should be added?
Thanks!
What course are you taking?
Bill
Ernst & Young LLP
This is the self-study online training. It looks like Cleaning and Rebuilding Solution doesn't actually clear the cache - any changes to "Context" I make in the XML are not reflected in Object Explorer until I close and re-open Pega Robotics Studio. Might have to do with my computer settings.
Thanks!
Did you ever find any resolution to this issue? I'm have the same problem on the same training.
Andrew,
I believe you are encountering a bug, the good news is there is a work around. I can not recreate the bug so I am working from memory, let me know if this works:
Do a Build > Clean Solution
Add a string variable component to the GC with the IntMgr (this could be any component, the purpose is to make the GC file "dirty" to force a change when saving)
Save GC
Do a Build >Rebuild Solution
You can now delete the string variable
Please let me know if this resolves the issue by marking this as the correct answer if it works.
Cecil
TTEC
Add a string or integer variable to your global containers (gc) where you have the Interaction manager component. Clean and rebuild the solution and try to run it. In the future, you should always close your gc after adding new context values, clean and rebuild the solution, then reopen your gc to see the updates.
