Wipro
Last activity: 10 Dec 2018 10:45 EST
Deserializing design component
Hi Team,
I am facing an error that occurred only when i run the bot and bot is not started due to this error. This happened when i integrated a new piece of code into existing code. I cleaned and rebuilt the solution. Still the same execution error. No build errors were there.
I am attaching the screenshot of error below. Please suggest how to resolve this error.
This indicates that you are using a variable in Main_CITPOC that is not inside your Global Container. It will probably be showing in red if you opened that automation. Deleting it and re-adding it should resolve this.
