Enable Street View using Google Maps control
We are working on Pega 7.3.1, and currently we have implemented some google maps functionality. The client has a new requirement in which they want to enable the street view using google maps. We have checked the js that the control uses and by default the value is set to false. We cannot override this value since the rule is Final (UI component definition), same goes for the control pxAddressMap.
Any suggestion how we can achieve this?
Thank you so much!!
JC
a hotfix has been provided, thank you!
