HCL
Enable Data Propagation
How to enable Data Propagation in Pega 7.2 version for Passing data to another case ?
I could not see 'Data propagation ' option in my exercise system.
Likes (1)
Kiruthiga S -
JPMorgan Chase & Company
You can propagate data from a parent case to each child case that is created at run time. By sharing property values among cases, you save time and provide relevant information to caseworkers.
Open a parent case type in Case Designer.
On the Settings tab, click Data propagation to display a list of child case types and the properties that have been propagated.
For example, Into Loan (2) is displayed when two properties are propagated from your case type into the Loan child case type.
Click a child case name to expand the section.
Click + Add property.
In the Propagate property value field, press the Down Arrow key and select the name of a property that is copied from the parent case at run time.
Tip: Enter a fully qualified name in this field to specify an embedded property. For example, enter .pyWorkParty(Customer).pyWorkPartyUri to set the pyWorkPartyUri property that is defined on the Customer page of the pyWorkParty page group.
In the To property value field, press the Down Arrow key and select the name of a property that is set in the child case at run time.
Click OK.
Optional: Select the Apply data transform check box and provide the name of a data transform that runs each time that a child case is created.
This data transform does not run when a child case is created by a Case step in a stage of the parent case type.
Tip: Reference the pyParentPageName page property in this data transform to access properties in the parent case type.
Repeat steps 3 through 8 to propagate the values of more properties from the parent case type.
Click Save.
At run time, values are propagated each time that a child case is added to the parent case.
Infosys Ltd
I am unable to find the "Data Propagation" under settings tab , please help me out.
Joyce Jenifer Rajasingh NAGA DURGA RAJESH IRRINKI
Data Propagation option for a case will appear only if it is a parent Case, I believe you don't have any child cases for it.
Thanks.
Capgemini
I too am experiencing this error. I am tasked with creating a data propagation from Parent to Child however when I select the parent case type, go to the settings I do not see the 'Data Propagation' that I can select. Do I already need to have the child case created?
Capgemini
I have found the solution from reading previous posts. Thank you. I needed to create the Child Case first then highlight the parent case and go to settings and Data Propagation will be listed there
Tata Consultancy Services
HAve you checked your case type rule?
Romero Borze Tara Pottebaum
