  Sensiple Software Solutions
Last activity: 16 Jan 2018 0:34 EST
Email Correspondence in Cascading Approval
Hi
Am having a requirement to route the case to mulitple approvers for purchase request approval.
I have used cascading approval - Reporting structure to route the case to appropriate approvers for approval. But am unable to configure the email correspondence for each approvals. Eg: I have two levels of approval like Manager and Director and I need to send email to the user(One who raises the Purchase request) once Manager approves/rejects the purchase request and also for Director's approval/rejection.
Can anyone help me to resolve this issue?
Thanks.
I see that the pxCascading flow is internally calling pyCascadingGetApproval flow which is available. So I guess you can tweak that.
If I understand correctly, you want to send the mail once it is approved or rejected. You can try this if you didn't, Add Send Email Smart shape after the cascading approval shape in the flow. You can configure the connector such that only if approval continues to send email shape.
Similar usecase:
https://pdn.pega.com/route-cases-approval-cascading-approval-smart-shape
Thanks Kakul. But if I add send email shape after cascading approval shape then one mail correspondence will be sent after both Manager and Director approval. My requirement is to send seperate email for Manager and Director approval.
Then, instead of Send Email smart shape, you can use a utility shape. Here in the activity use sendSimpleEmail activity in two steps. Differentiate the Manager and Director with the when conditions. For each, you can use different correspondence.
  Dinesh Gnanamoorthy
Thanks kakul. Actually I want to customize the cascading approval shape to send email correspondence for each approval. If you add SendEmail or Utility shape after cascading shape then email will be sent after all approvals(Manager and Director). I want to send email to user once the Manager approves the request and another email to user once the Director approves the request.
Yes you can try that but I think it should be some pz rule which you can't modify.
Yes. Can you tell me any other possible way to achieve this requirement.
