eForm unable to extract data
Pega Platform: 7.3.1
I have a fillable PDF. (currently configured to not be savable)
Using the PDF for EForm Wizard, I was able to get the EForm File and Map eForm Rules created.
Using the OOTB functionality, I was able to map from a WorkObject (pyWorkPage) into the generated PDF as expected.
Via an Activity, if I try and use the OOTB calls or EFormUtils java code to read that same PDF back into pyWorkPage, the values are not reflected via tracer steps or clipboard.
Two questions:
1. Is there anything I have missed?
2. Is the fact that the PDF is non-savable causing issues?
thank you,
Rob
