DX API - PUT 'refresh' action doesn't update conditional visibility on fields
Good morning,
I have a problem retrieving conditional visibile fields on the DX API.
I have a simple boolean radio button 'AccettoRifiutoAgenzia' (with ofc a property attached), and two specific field, each one conditionally visible only when the property attached to the radio button is true or false.
On the OOTB FE, when i click on the radio buttons it shows me the right field, but when executing a 'PUT' http call like the following:
'http://.../api/v1/assignments/.../actions/CollectInformationAgenzia/refresh?refreshFor=AccettoRifiutoAgenzia'
with the correct body (in fact the response of this put returns me the view with the right value that i have just pressed on the radio button), i still returns me both the fields with visibility false.
If i check 'Run visibility condition on client' i have the opposite results, having every time both the fields visible.
This is a pic of one of the two fields:
I am pretty sure that the http call is correct, as I am already using it to update data transform when selecting different type of inputs.
Has everyone ever encountered this problem before?
Thanks in advance,
Nicolò
