Does pxChangeStage also remove SLAs?
We need to call pxChangeStage to change to a previous Stage in our case. If I check the CleanUpProcesses checkbox will Pega clean up any SLAs associated to my case (along with the Assignments)?
@SteveT Cleanupprocess will remove the open assignments and hence the associated SLA(if you see pzInternalFlows which got created to track the SLA will also get removed). Hence SLAs also gets removed from the queue.
