Coforge
Last activity: 26 May 2017 7:14 EDT
does not exist for use by this record(Validate)
i am getting below error.
Body Include: ABCtab does not exist for use by this record(Validate)
Section name:ABC
i have verified below scenarios
1. Applies to class of section ABC exists in inheritance path
2. Availability of the section ABC is yes
***Updated by moderator: Marissa to update categories***
Likes (1)
Pradip Kavade -
Coforge
Hi Team,
Due to Pre-requesite issue, this Error was displayed.
Vishnu
Thanks for your question. Could you please tell me the course are you taking so I can help?
-Maryrita Styer
Community Manager
Coforge
I am facing this issue in real time project. and version is 7.1.6
Vishnu
***moved to Product Support Community by Maryrita Styer Community Manager***
Vishnu,
Could you provide more information / screenshots showing exactly what you're trying to save? What rules are involved here? What's the context?
Coforge
Hi Team,
Vishnu
RuleTek
I'm getting this error too. I'm editing a section, and it won't let me save or check in/out. It only offers save as and private edit. I clicked private edit, which changed the save as to save. I then click save and got that error.
Also, no matter how many times I delete the default section, it keeps reverting to it, and won't save my changes.
I'm working inside a portal harness in one of the sections held by the harness, after editing defaults.
Evernorth Health Services
Problem: I too faced the same problem. I tried adding a new validate rule in a flowaction - validation tab, done this in private edit.Got the same error "********does not exist for use by this record(Validate)"
Solution: I saved the Flow action to a branch first instead of private edit and then added the validate rule, it worked without errors.
Ginjupalli Bharath Yash Jain Gaurav Londhe Vinesh Tatineni RaviAchari Thumburi
