AtoS
Last activity: 12 Feb 2016 1:44 EST
display particular screen when previous process is completed
In my application there is one requirement that current screen will only display when previous process is completed.
Virtusa
Hi Mustak,
Could you please give further details like the PRPC version you are using and the scenario which you referred.
AtoS
Hi Aruldevan,
I am using 7.6 version. In my application one business requirement is that i need to display one screen only when previous process ( in previous case if all process of business logic met then only in next case that screen will display )
Thanks.
Hi
You said, " in previous case if all process of business logic met then only in next case that screen will display"
Question :
1. What is the relationship between previous and next case ? Do you mean stage by any chance ? Or is it like parent - child relationship or something else ?
2. Have you considered using flag property and then use the property in a decision shape to route the assignment properly ?
Virtusa
Hi Mustak,
In addition to the queries from Santanu, Could you please give details on the below too.
Are you ststing the next screen as the screen of the parent case.
Do you want to proceed with the parent case when completion of the child case.
Thanks.
AtoS
Yes Its Parent Child Relationship case and want to proceed when child case completed.
UnitedHealth Group
Hi Mustak Panja,
Based on what you have stated, you can add a Wait Shape on the parent flow which resumes on the Case Dependency as shown below.
Here you can configure your parent case to wait for your Child Case to reach a particular status.
Let me know if you need more information.
Hope this helps.
Prasad
AtoS
Hi Prasad,
Thank you very much for your reply...
Mustak Panja
UnitedHealth Group
Hi Mustak,
Were you able to achieve your requirement by adding Wait shape?
Prasad
AtoS
Hi Prasad,
That task is on hold due to business. Once business will come with new added requirements then will implement it and let you know..
