Disabled Dropdown Options?
Hello everyone,
I'm hoping someone can help me out with this. I am working with a dropdown control where some options are visible but are "disabled" and not selectable (screenshot below). After searching in the control, flow action, section, layouts, etc. I still cannot find out how this is functioning.
I would like to do the same functionality of disabled dropdown options somewhere else in the application but it seems to me that this is not an OOTB functionality.
Here are some screenshots below of the General, Presentation, and Actions tabs of the dropdown control. Any insight into how this is being done would be very helpful.
Hello everyone,
Thank you - Gabriel
Here is the solution I have come up with:
This is not an OOTB functionality and must be done by including JavaScript code in the HTML tab of a section. I found a section fragment (blank section) on one of our main sections and on the HTML tab of that section, was some JS code that conditionally set the dropdown options to be "disabled".
Here's the code I included on the HTML tab:
<script>
if(document.getElementById('CeCDAcctSeq'))
var dropdownOptions = document.getElementById('CeCDAcctSeq').options;
var listItem = "";
for (var i = 0; i < dropdownOptions.length; i++)
listItem = dropdownOptions[i].text;
if(listItem.indexOf('[ER]') !== -1 || listItem.indexOf('[EE]') !== -1)
dropdownOptions[i].disabled = true;
if(dropdownOptions[i].disabled === false)
document.getElementById("CeCDAcctSeq").selectedIndex = i;
</script>
