FAA
Last activity: 21 Jan 2022 11:11 EST
Disable creation of Operators
On Pega (Government Platform) 8.4.4. We use SAML SSO, and new Operators are created automatically using a model operator.
SAs are assigned the "Author" access group in our standard base app after creation, and they can create new applications, which is good. However, they can create and modify operators as well. I would like to remove that ability from the Author access group.
It appears that the Author access group is based on [standard base app].Administrator and PegaRULES:SecurityAdministrator roles. If I remove PegaRULES:SecurityAdministrator from the Author access group, will that do the trick? Or is my whole approach flawed?
Thanks in advance.
@Alan Thompson You can create a new Access role for the access group and customize it accordingly.
Regards
Bhavya
