Disable check in mechanisam if any warning
Can we restrict the Check in functionality if there are any Guardrail warnings present on a rule?
looks like this could be helpful:
https://collaborate.pega.com/question/rule-check-without-warning-justification
There is a PreCheckInDialogExtension activity that you could use for custom code or you could use the rule check-in approval process.
Rule check-in process
https://community.pega.com/sites/default/files/help_v731/procomhelpmain.htm
This discussion post has similar information as well that may be helpful.
https://pdn.pega.com/community/product-support/question/compulsory-warning-resolution-check
