Difference between connectors and services
It is not very clear to me when I should use a service and when I should use a connector. They seems to do the same thing, integrating an external system to the pega platform. They both push and pull data and docs ( if I got it correctly).
Can someone explain the difference of those two functionalities?
Please find the below article which might be helpful.
https://community.pega.com/sites/default/files/help_v84/procomhelpmain.htm#concepts/concepts2/conceptssysteminterfaces.htm
