Deloitte
Last activity: 8 Mar 2017 7:13 EST
Deployment using ANT / MAVEN / Jenkins
Could anyone please list out the steps or share any document of performing a continuous integration process using ANT / MAVEN or Jenkins?
How different is the deployment process in PRPC v6.x compared to v7.x?
I have gone through below links but they aren't much helpful.
https://pdn.pega.com/forums/testing-applications/how-invoke-prpc-test-suites-jenkins-job
- ANT - export and import script:
https://pdn.pega.com/system-operations/how-to-import-and-export-zip-archives-from-a-command-line
- Pega deployment using Jenkins (CI)
https://pdn.pega.com/forums/pege-deployment-using-jenkins/pege-deployment-using-jenkins
Thanking you
Updated: 9 May 2016 23:26 EDT
I suppose there is no standard document/article available to suffice your requirement as this is not productized. There seems to some custom tasks/jobs involved when I looked into this thread https://pdn.pega.com/forums/testing-applications/how-invoke-prpc-test-suites-jenkins-job
Deloitte
Thanks Harish for pointing to the thread which may help but this doesn't provides us with the entire requisite info.
@ Members - Please let me know if anyone knows the steps to do Deployment using ANT / MAVEN / Jenkins ?
Srikanth,
FDBK-15450 has been submitted to the product documentation team.
We will keep you apprised of its status.
Please edit your post to add FDBK-15450 to the Related Work field.
Thanks!
-Mary
Thank you Mary Carbonara for submitting this! I have updated the Related Work field with the Feedback number.
FDBK-15450 has generated US-133587 for a PDN Article (In progress now) that explains how to set up Jenkins for RAP deployment.
Srikanth,
Because your Mesh account is private, I could not send you a private message (or see your company affiliation) to ask the following questions:
- What is the business impact of your need?
- What is your timeline? Urgency?
Knowing the answers to these questions will help Pega Product Management assess and triage FDBK-15450.
In the meantime, the following PDN Article might help you:
It describes the use of Jenkins to automatically execute Data Page unit tests. Of particular note, the section Configuring your build environment is relevant to the article that you requested in your post here and now being tracked under FDBK-15450.
Also, a new PDN Article about using Jenkins is planned for a future product release.
Srikanth,
And finally, did you also post a similar question to the PDN Forums?
I searched the PDN Forum posts that seek info about Jenkins, but did not find any post by you.
Would you mind sharing your PDN link? (If you prefer not to, that's OK.)
Thanks for helping us clarify your need for the requested documentation!
(You can send me a Mesh private message, if you prefer that mode of communication.)
-Mary
Deloitte
Thank you for your detailed response Mary. I have sent you a message. I would like to let you know that I am not able to access FDBK-15450 either.
Srikanth.
Hi Srikanth,
That's correct: You and other external customers cannot view Pega-internally tracked BUGs, FDBK items, User Stories (US), and other case objects.
We cite these case objects for your reference so that Pega SMEs can apprise you of status and other information.
They are case #s for your reference only.
As I mentioned in our Mesh private message, I have added the business impact that you provided to FDBK-15450.
Thanks very much!
-Mary
Ernst & Young LLP
Did you find the steps for the automated deployment using Jenkins? I have a requirement, will you be able to help?
Ankur
Hi Srikanth,
Thanks very much!
-Mary
