Deploy PRPC 7.1.8 behind proxy, SMA can not get real client IP
Dear all,
Our system has F5 proxy direct connect to WAS cluster with some ports. In the SMA I only see the client ip is ip of Load Balancer. Is there anyway to get the real ip of client? How to do that?
Load balancer ip will shows always, even if you want this node connect remotely in SMA then also you have to provide remote host as this load balancer host.
