Mphasis
Last activity: 13 Aug 2015 13:16 EDT
Problem with Integrating SiteMinder with PRPC 7.1.8
We are facing an issue with integrating SiteMinder with PRPC 7.1.8. We are following the runbook (Attached) and in page 20, an option for importing ldP metadata is mentioned. I have attached the sample file that I tried to upload in the PRPC authentication service, but nothing shows up over there even after we import (fields such as Entity Identification, Login (SSO) Protocol Binding, Verification Certificate, TLS/SSL truststore are blank. I have attached the file (1_DevPegaPRwebSSO_1.xml) that we were trying to upload. Is there any problem with the tags used or are we missing something?
For metadata exchange testing with Stieminder we simply exported the IDP information from Siteminder and them imported it. It was that easy. We also tested with the lasted version of Siteminder so maybe your using an older one?
Before I dive into this further I just wanted to confirm that you modified temp1_1_DevPegaPRWebSSO1.xml before you attached the file replacing elements you don't want on a here with "XXXXX". I will compare what we have etc.
I also noticed the you only defined a HTTP-Redirect binding for your Single Signon. When working with CA on the Runbook they mentioned they prefer HTTP-POST.
