Cognizant Technology Solutions India Ltd.
ES
Last activity: 17 Jul 2017 16:39 EDT
Delete safely rulesets through SQL script
Customer has three regions and they are full of junk rule and data. How can we delete rulesets in bulk safely through SQL script?
Pega provided Ruleset delete wizard is not working properly to delete a ruleset. It's stuck and shows the screen calculating ...rule count. I tried deleting version wise but that will take months to delete all the rulesets as there are 100s of rulesets. Any idea or suggestion.?
I am thinking to do it as below. Can somebody sugest this is a safe way to do it?
Back up
Create Table pr4_base_bck as select * from pr4_base where pyRuleSet = ‘RulesetName’
Create Table pr4_fieldvalue_bck as select * from pr4_fieldvalue where pyRuleSet = ‘RulesetName’
Create Table pr4_rule_bck where as select * from pr4_rule where pyRuleSet = 'RulesetName'
Create Table pr4_rule_file_bck as select * from pr4_rule_file where pyRuleSet = 'RulesetName'
Create Table pr4_rule_flow_bck as select * from pr4_rule_flow where pyRuleSet = 'RulesetName'
Create Table pr4_rule_property_bck as select * from pr4_rule_property where pyRuleSet = 'RulesetName'
Create Table pr4_rule_sysgen_bck as select * from pr4_rule_sysgen where pyRuleSet = 'RulesetName'
Delete
delete from pr4_base where pyRuleSet = ‘RulesetName’
delete from pr4_fieldvalue where pyRuleSet = ‘RulesetName’
delete from pr4_rule where pyRuleSet = 'RulesetName'
Back up
Delete
delete from pr4_rule_file where pyRuleSet = 'RulesetName'
delete from pr4_rule_flow where pyRuleSet = 'RulesetName'
delete from pr4_rule_property where pyRuleSet = 'RulesetName'
delete from pr4_rule_sysgen where pyRuleSet = 'RulesetName'
***Updated by moderator: Marissa to close post***
