Accenture
Last activity: 5 Apr 2016 12:44 EDT
How to handle Unlocked RuleSet Exception in Automation script.
I Added an Unlocked RuleSet,RuleSet Version into a Product(RAP) to move the code to Higher environment. And i didn't check the option "Allow Unlocked RuleSet Versions? " and Saved it.
While creating the Jar file, it is giving error as shown below.
"The Product is referencing unlocked RuleSet Version instances, please follow the links below to lock them or update your Product rule to allow unlocked Versions to be exported. Be sure to save the Product rule if allowing unlocked RuleSet Versions to be exported, otherwise your change won't take effect."
The above is error is expected.
Now I tried to pull out the Jar file from the Product(RAP) using Automation script(Utils under script which will be shipped along with PRPC installable files).
The Jar file is created.
How to identify this exception in the logs of script. Do we get any warning in the logs?
Why the script is still proceeding with the Jar file creation even the Product is not proper(i mean either we need to lock the ruleset or we need to select the option "Allow Unlocked RuleSet Versions?" in Product while creating it)?
But i can see some errors in log file as shown below.These errors are representing the same unlocked RuleSet thing?, if yes, how to handle this?
[java] 2016-03-15 15:51:49,720 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Cannot open the requested instance '': class or class group "" does not exist.
[java] 2016-03-15 15:51:50,284 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.util.CollectorImpl) ERROR JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Error adding . Class <blank> does not exist
[java] 2016-03-15 15:51:50,285 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Cannot open the requested instance '': class or class group "" does not exist.
[java] 2016-03-15 15:51:50,297 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.util.CollectorImpl) ERROR JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Error adding . Class <blank> does not exist
[java] 2016-03-15 15:51:50,297 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.access.DatabaseImpl) ERROR JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Cannot open the requested instance '': class or class group "" does not exist.
[java] 2016-03-15 15:51:50,298 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.util.CollectorImpl) ERROR JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Error adding . Class <blank> does not exist
[java] 2016-03-15 15:52:52,323 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.util.MoveLog) INFO JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Operation Status: Exporting 629 instance(s).
[java] 2016-03-15 15:52:52,324 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.util.MoveLog) INFO JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Operation Status: Exporting Inventory
[java] 2016-03-15 15:52:56,273 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.access.SQLGenerator) WARN JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Unable to locate case-sensitive column name PXREQUIREDSKILL on table KPN_CM_INDEX_ORDERLINES. If this table will be accessed by Obj-* methods, create the corresponding Rule-Obj-Property definitions, otherwise if this is an external table to be accessed by RDB-* methods, disregard this message.
[java] 2016-03-15 15:52:56,281 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.access.SQLGenerator) WARN JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Unable to locate case-sensitive column name PXSKILLNAME on table KPN_CM_INDEX_ORDERLINES. If this table will be accessed by Obj-* methods, create the corresponding Rule-Obj-Property definitions, otherwise if this is an external table to be accessed by RDB-* methods, disregard this message.
[java] 2016-03-15 15:52:56,294 [localhost] [ STANDARD] [ PegaRULES:07.10] ( internal.access.SQLGenerator) WARN JSR94|Deployment|Utility|pxExportApp|A02417A6FF46CF845619819D754114479 - Unable to locate case-sensitive column name PXSKILLRATING on table KPN_CM_INDEX_ORDERLINES. If this table will be accessed by Obj-* methods, create the corresponding Rule-Obj-Property definitions, otherwise if this is an external table to be accessed by RDB-* methods, disregard this message.
