LTIMindtree
Last activity: 7 Aug 2023 10:33 EDT
Default memory accepted for #custom.jvm.args argument in SetupDatabase.properties file
We are planning to upgrade our application from pega 7.4 version to 8.6.4 version which is running on azure cloud using jboss middleware. Before running upgrade script we set all the required parameters in SetupDatabase.properties file ,but need clarity for one of the arguments as mentioned below . Bydefault the below argument is taking 4 gb when we are running the upgrade. So we want to know the default memory accepted for the below argument .
#custom.jvm.args=-Xmx4g
***Edited by Moderator Marije to change type from Product to Update , added Product details and Capability tags****
@sanjeeb tripathy I would suggest that you ask this question in the Ask the Expert - Pega Database with Jie Long session which is currently open.
