Dedicated schema for Framework rules to be used across Enterprise
Hi, We are building a Global framework across enterprise which can be used by multiple applications.
Every time we create a new ruleset version and change rules, the Global framework needs to be packaged and imported in all the different applications, which is a difficult task.
If the framework rules reside in a dedicated PegaRules Schema (for Global framework), all the applications in the Enterprise will be able to connect to this schema and there is no need to sync-up (export/import framework package) in all the applications.
Do we have any solution for this?
***Updated by Moderator: Lochan. Removed user added #helpme and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
