Golden Gate Replication across Oracle Database with PRPC7.1.7
I am in the process of installing Oracle GoldenGate replication across two ODA. The following is the configuration and version of the system
Database version: Oracle 12c
Schema type: Split
GG version: 12
When whe initiate the replication process we receive the following errors
Replicat 1 :
2015-08-31 10:59:23
WARNING OGG-01154 SQL error 1 mapping GNA_RULES.PR_SYSGEN_STATIC_CONTENT
to GNA_RULES.PR_SYSGEN_STATIC_CONTENT OCI Error ORA-00001: unique constraint
(GNA_RULES.PR_SYSGEN_STATIC_CONTENT_PK) violated (status = 1), SQL <INSERT
INTO "GNA_RULES"."PR_SYSGEN_STATIC_CONTENT"
("PXCOMMITDATETIME","PXCREATEDATETIME","PXCREATEOPNAME","PXCREATEOPERATOR","PXCREATESYSTEMID","PXINSNAME","PXOBJCLASS","PYAPPLICATIONNAME","PYBASEFILENAME","PYFILENAME","PYFILETYPE","PZCACHECONFIGID","PZPACKAGE","PZCLASS","PZINSKEY","PZPVSTREAM")
VALUES
(:a0,:a1,:a2,:a3,:a4,:a5,:a6,:a7,:a8,:a9,:a10,:a11,:a12,:a13,:a14,EMPTY_BLOB())
RETURNING "PZPVSTREAM" INTO :dl0>.
Replicat 2 :
2015-08-31 08:06:54
WARNING OGG-01154 SQL error 1403 mapping GNA_DATA.PR_LOG_REPORTSTATS to
GNA_DATA.PR_LOG_REPORTSTATS OCI Error ORA-01403: no data found, SQL <DELETE
FROM "GNA_DATA"."PR_LOG_REPORTSTATS" WHERE "PZINSKEY"
= :b0>.
Has anyone ever run across this problem or is using GG for replication on PRPC 7.1.7.
