700 Applications
Last activity: 16 Dec 2025 7:38 EST
DB Table Naming Convention: Character Limits and Migration Best Practices
Dear All,
We have created a new Work class and its corresponding physical work table in our lower environment (DEV). When we migrate this configuration (via a Product Rule) to the QA environment, Pega attempts to generate a CREATE TABLE SQL statement using a different, auto-generated table name than the one used in DEV.
We observed that this discrepancy occurs because the intended table name exceeds 30 characters (the name is 36 characters long).
We understand we can work around this by manually running a SQL script in QA first to create the table with the expected name, and then importing the Pega code. However, we have two primary questions regarding Pega best practices:
- Is there a standard maximum character length for database table names that Pega officially suggests or adheres to? If we go beyond it any issue that we face? (Specifically, we want to know why Pega sometimes generates random, truncated names, and if we should rename them.)
- What is the recommended best approach for migrating database schema changes (like new tables/columns) from Development to higher environments? Should we rely solely on the Pega product import wizard, or is the standard approach to handle DB changes with SQL scripts first and then import the Pega code/rules?
Thank you.
