Data transform only works if it is checked out
I have a data page that calls a REST service. The service has a request and response data transform to map the parameters in and the responses received. If I have the response DT checked out, it works fine. If I check the response DT in, it fails with the following errors:
PRRuntimeError: Failed to compile generated Java com.pegarules.generated.model.ra_model_runhistoricalsearch_response_5c9f2169090f359194d70ad1b7956238: Annotation processing got disabled, since it requires a 1.6 compliant JVM ---------- 1. ERROR in /com/pegarules/generated/model/ra_model_runhistoricalsearch_response_5c9f2169090f359194d70ad1b7956238.java (at line 78) actionProlog(pz_CurrentTraceInfo,"1", "Append and Map to", pz_3, targetProperty_1); ^^^^ pz_3 cannot be resolved to a variable ---------- 2. ERROR in /com/pegarules/generated/model/ra_model_runhistoricalsearch_response_5c9f2169090f359194d70ad1b7956238.java (at line 119) actionEpilog(pz_CurrentTraceInfo,"1", "Append and Map to", pz_3, targetProperty_1); ^^^^ pz_3 cannot be resolved to a variable ---------- 2 problems (2 errors) Compile failed.
I can re-create the issue over and over by just checking in (fails), check out (works), discard changes (fails). I even tried creating an entirely new data page and DTs all with different names, but that does exactly the same thing and gives the same error message.
I found reference to this article (https://community1.pega.com/support-articles/page-set-data-transform-does-not-work-when-rule-checked) which was marked as the solution in this similar question (https://collaborate.pega.com/question/datatransform-not-executing-when-rule-checked) unfortunately the link to the article is broken so it's not very helpful.
Any suggestions would be greatly appreciated. Thanks.
