    Younicorp
Last activity: 15 Feb 2023 2:33 EST
Data objects Knowledge check: Preference has No system of record, why?
I was executing the knowledge check on the Data Objects topic and came across something I couldn't quite grasp.
In this exercise there's a few data objects that you have to assign to either Pega SOR, External SOR or no SOR. The exercise is explained like this:
You are building a new customer service application in Pega Platform, with a case type that allows customers to submit feedback on orders that they placed with a legacy product application. Customers can specify their preference for the application display, which affects how they enter feedback. The following data objects are necessary:
- Preference for the user preference for the application display in their browser
I left out the other three Data Objects, since my question is solely regarding the Preference Data Object. If I'm looking at the image a little higher up in that topic, there's several questions to determine whether and what SOR you would need.
The first question is "Do you need to save the data outside of the case?". The preference object doesn't have a connection with the specific case, since it's to determine user preferences.
I figured I needed to save these preferences in an SOR, so that the next time the user opened the application, the preferences could be preloaded again.
Why is the correct answer that the Preference object should have no SOR?
Kind Regards,
Kind Regards,
Daniël Pollmann
