Customize Pagination
Hi, I would like to customize the pagination. Currently it's showing black border and numbers, how can I change the colour of the border and numbers?
Hello Joyce,
Thanks for your time over posting your query on PSC.
You can customize the Pagination styles in the SKin>>Reports>>Pagingbar. you can make changes to border and numbers.
else, if your requirement is for the particular report, you can configure the non-autogenerated section and customize the pagination styles.
Naveen
Hi, I tried the method of customizing the style via the skin. However, I realised that my pagination styling is slightly different from the one in the skin. The one in the skin changes the external border that contain the whole pagination. However, each of my number in the pagination is separately via a box itself. I have attached a image of my pagination style below. How can I customize it to change the number and each individual box of the pagination?
Hello Joyce,
Thanks for sharing the screenshot, looks like it is already customized. You may inspect the pagination element and override the styles in userworkform(OOTB HTML fragment).
Adding to naveen , can you check your skin overrides ?
It can be done through skin only
