Sri Manakula Vinayagar Engineering College
Last activity: 28 May 2025 12:10 EDT
Customizing pagination activity
I'm retriving above 50,000 records from db for that its taking time to load harness, in data page i'm using activuty to retrive data,so i decided to use pagination in section it should work like pxAdvancedPaginateForEmployees, on click of page number another new 60 records should retrived, how to achieve this...
Reply
You can implement OOTB Pagination or Progressive loading in the report definition rule.
@RameshSangili Thank you for the response
yeah i have already enabled that option still its taking time to get load so i thought to add pagination activity in section,but didn't know how to configure that
Narayanamurthy PS.
Updated: 6 Jun 2024 12:52 EDT
@MadhavanS16795014 - To get the records dynamically from the data page call instead of clipboard. If the table source is Data page , In definition tab will have "Allow querying any column (Pega connection only)". This feature will retrieve the records on demand i.e. if first page has 10 records clipboard also holds 10 and clicking on second page it loads next 10 records and clipboard will be updated. It wont load all the records in clipboard.
If the unable to find option "Allow querying" if the platform version is bit older then in load management tab we see "Enable pagination"
https://docs-previous.pega.com/data-management-and-integration/87/specifying-queryable-data-page
Thank you.
yeah it's fine with data source as report definition...
But in my case i am using activity which retrives 40K records....?
any other solution for this ......?
@MadhavanS16795014 - Source this activity to the data page and make use of allow querying option to optimize the records in run time.
Thank you.
Hi Priyanka, thank you for the reply,
i have tried your suggestion but still its taking time to load screen its taking over 30 seconds to get load with data,
and i am looking like there will be any grid regarding activity to add in table layout under specify pagination activity option....
Thank you...
Madhavan S.
YuniQ
We tried this approach, but it's not working as expected. The data page is still fetching all records from the DB, instead of handling pagination at the database level.
It seems like OFFSET and LIMIT are not being applied in the SQL query generated internally. As a result, all the rows are getting loaded into the clipboard, which affects performance.
Could you please confirm if this works only with specific platform versions or if there’s any additional configuration needed to apply OFFSET / FETCH dynamically?
Karthik
Updated: 17 Jul 2024 5:00 EDT
HCL Technologies Ltd
We have multiple approaches for this requirement. One of them is as follows:
1. Use an activity and configure the activity in a data page as a source.
2. Configure a table layout in a section.
3. Set the source of the table layout to the data page.
4. Add pagination to the table layout.
Please check the image below for reference.
Mohd Qizer Uddin
Yeah, thank you
i have enabled that pagination, under that i have to implement pagination activity
after enabiling that checkbox...
Madhavan,
