Criteria filter and taxonomy Pega Knowledge
By default, end users can only filter their results on the first taxonomy which is on the article. Is-it possible to also have the all the other taxonomies used and select it as a filter criteria on CRM search engine ?
If not, it is not really a criteria filter. The name of the criteria should be changed.
Every articles has several categories in Pega Knowledge.
Thank you,
