CredentialManagerConfig.xml - Reference same network file from multiple bots
We're attempting to install Robotics Proprietary information hidden on Windows2022. In this setup, we'd like to configure our bots across a stack to reference the same credentialmanagerconfig.xml reducing the effort to maintain the file across the environment.
We've attempted to update the CommonConfig.xml CredentialManager property to a direct path, but it fails to resolve this. It seems to only accept a few preset environmental variables.
To work around this, we attempted to use a symlink mapping the path to the credentialmanagerconfig.xml directly to the target config on NAS. I'm able to access it manually, but when starting the RPAService, it gets an access error reaching the symlink (C:\ProgramData\Pegasystems\CredentialManagerConfig.xml -> NAS CredMgrConfig.xml):
MTA | Service | Access to the path 'C:\ProgramData\Pegasystems\CredentialManagerConfig.xml' is denied.
System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\Pegasystems\CredentialManagerConfig.xml' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials, IWebProxy proxy, RequestCachePolicy cachePolicy)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state)
at System.Xml.XmlTextReaderImpl.OpenUrl()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at OpenSpan.Security.Configuration.CredentialManagerConfigHelper.LoadCredentialConfig()
at OpenSpan.Security.Configuration.CredentialManagerConfigHelper..ctor(ISecureDataStoreLogger logger)
Is there a means of mapping multiple bots to use the same CredentialManagerConfig.xml?
Thanks!
@ChrisF97 That makes sense. I will let our product team know and perhaps they can create a future enhancement. If you feel this functionality is needed with more urgency, you can open a support request to get a formal feature request submitted.
